If you’re experiencing problems and want to reset your 3Dconnexion configuration, the easiest way is...
By default, EDEM has SpaceMouse navigation disabled and uses Target Camera navigation, which inverts most...
After installing the latest version of our 3dxWare driver (v10.8.9) driver on macOS, users experience...
Lychee Slicer uses Target Camera navigation by default, which inverts all axes compared to Object...
Starting with 3DxWare 10.9.4, installation on Windows ARM systems is possible. You might experience the...
Because mapping of 3Dconnexion buttons in Blender 4.4 and higher is done differently than in...
Because mapping of 3Dconnexion buttons in Blender 4.3 and higher is done differently than in...
After the Windows 11 update 24H2, you may encounter issues with your mouse wheel. If...
Once you have installed the 3Dconnexion driver, it’s essential to enable the 3Dconnexion extensions, such...
Possible reason for this issue: If your installation is stuck, it might be caused by...
What is the Global Settings feature? Global Settings is a new feature introduced with 3DxWare...
Your image will look its best on all 3Dconnexion (on-screen) displays, if it is 24...
1. Installing the Plugin Starting with Unreal Editor version 5.4, the 3Dconnexion Plugin is no...
Some users do not see their 3Dconnexion device listed during Bluetooth pairing on newer versions...
To find your driver version please follow instruction below: Windows: Go to Windows Search and...
SpaceMouse is not enabled by default in ParaView. However, you can easily enable it by...
SpaceMouse integration has been upgraded in FreeCAD 0.22 nightly compilation / FreeCAD 1.0 Release Candidate...
In case you’re experiencing a sluggish navigation, disabling the "Allow navigation during redraw" option can...
Disable "Allow navigation during Redraw": Marking this checkbox will disable the "Allow Navigation during Redraw"...
For the best experience and the latest features, we recommend always using the most up-to-date...
Post-warranty service is not provided. However, some spare parts are available, for instance sliders feet....
Move Objects: Enables the movement of selected objects inside the scene. Pause Motion: Disables SpaceMouse...
If your device requires firmware update please follow the instruction below: Plug your device directly...
While the 3Dconnexion driver does not directly allow to reverse the mouse wheel direction, it...
In order to use NX with 3Dconnexion device buttons it is necessary to load the...
In order to use SketchUp with 3Dconnexion devices it is necessary to load the latest...
In case the driver could not connect to the Add-In for SOLIDWORKS the 3Dconnexion devices...
Citrix Workspace app 2302 for Windows prevents the SpaceMouse from working. When the 3Dconnexion driver...
We do not recommend moving the cursor with a SpaceMouse but - in special cases...
Some administrators and users wish to move their 3Dconnexion configuration settings (profiles) to a different...
Evaluating and understanding your needs helps us to improve and tailor our products and services...
There is an option for including Unity support during installation of 3DxWare which must be...
1. Installing the Plugin IMPORTANT: First install Unreal Engine and only then install 3DxWare...
If the SpaceMouse does not work but instead moves the mouse cursor on macOS, the...
During installation of 3DxWare, the following error may arise with the progress bar at 50%...
How to choose your preferred decimal separator - dot and/or comma For every application, you...
If your CadMouse device works but does not click, please check first how you connect...
It is possible to synchronize your 3DxWare (Driver) settings between multiple machines using a Cloud drive. This works as...
Move Selected Objects: Enables or disables the independent movement of sub-parts within an assembly....
Move Objects: Enables the movement of selected objects inside the scene. Only Navigate the 3D...
For some applications you will find a tab with Other Options within the Advanced Settings...
If you want to report an issue with your 3D software and our driver it...
In our web shop our products have a part number that starts with 3DX-7..., e.g....
We regret the delay of our extension for Trimble SketchUp Pro 2021. The extension will...
The following table lists the discontinued devices from 3Dconnexion. Product Hardware Warranty [1] First Day...
Cinema 4D 2023.2 and higher Ensure the latest 3Dconnexion driver was installed after Cinema 4D...
In Creo go to: File > Options Choose “Model Display” from the left-hand column Enable...
In 9.3.1 (also called 9.31), there is a tab on the /File/Preferences Dialog box that...
The following procedure describes how 3ds Max (application and plug-in) should be set-up to generate...
Issue: The SpaceMouse does not roll or spin the model in a parallel viewport of...
1. Introduction In macOS 10.14 (Mojave) Apple introduced additional security features and tightened security once...
There are three ways to check the battery level of your wireless 3Dconnexion product. These...
I cannot navigate in Onshape Make sure you have the latest driver installed. Supported web...
3Dconnexion recommends cleaning 3Dconnexion products only with isopropyl alcohol (99%). Using conventional cleaning products or...
On macOS 10.13, customers will need to manually enable 3Dconnexion’s driver (version 10.5.0 or newer)....
3Dconnexion is aware that some early batches of our CadMouse product line show signs of...
Note: Windows 7 does not support Bluetooth Low Energy! On Windows: 1. Open the device...
Please follow the steps below in order to connect your CadMouse Wireless or CadMouse Pro...
The SpaceMouse® pairing tool enables the pairing of a wireless SpaceMouse with a dedicated USB receiver. Once a SpaceMouse and receiver are paired, the...
With the latest drivers, 3DxNX is installed in the 3DxWare installation directory, and references are...
For Creo versions 2.0 M150 to M210 and Creo 3.0 M040 to M080, if there...
If your device is not working in a supported application this may be a permissions...
The downloaded driver package of 3DxWare 10 for Windows may be extracted two times in...
For detailed parts and assemblies performance problems may occur during movement due to the high...
This article describes 3Dconnexion's approach to the creation of "3Dconnexion CA (auto-generated)" digital certificates. Use...
Problem The 3Dconnexion driver installed properly, but the properties panel cannot be opened to adjust...
If the driver panel shows in the "Tool" tab Firmware 0.00 and "No device found"...
If the receiver is placed in a position which is not electromagnetically critical, the operating...
The 3DxNumPad Unhandled Exception error occurs when there is data corruption in the "user.config" file...
3Dconnexion follows the USB specification, therefore our wireless devices can be charged by any micro-USB...
The USB cable is 1.5m long.
Customers can order additional USB cables from the 3Dconnexion webstore. Alternatively, any bi-directional micro USB...
The battery life can be maximized by turning off the SpaceMouse Wireless when it is...
SpaceMouse Wireless, SpaceMouse Pro Wireless, CadMouse Wireless and CadMouse Pro Wireless (Left) can be used...
Open the menu "Tools -> Options". Go to the tab "Navigation". In the section "Non-mouse...
This information is from HP from RGS version 5.4.8: Remote USB for the RGS Receiver...
You can order additional USB receivers from the 3Dconnexion webstore. Please visit this website to ensure...
When activating the On-Screen Display feature, the system may report that 3DxVirtualLCD.exe has stopped working....
If you are using Catia in a language that doesn't match your system locale you...
If an application is not listed under All Supported Applications, this application likely has no...
The 3Dconnexion devices have a plug-in for NX called "3Dconnexion Plug-In for NX" or "3DxNX"...
After installing your 3Dconnexion Software, you will find a new Icon on your desktop representing...
In Google Earth Desktop the support for the SpaceMouse is not enabled by default. You...
Official Windows 7 support is available on 3DxSoftware release version 3.8 and newer and on...
This guide is intended to provide the information needed for an IT Administrator to distribute...
Issue: Installation of the 3Dconnexion Add-In for SOLIDWORKS fails with error 1603 Solution: Please verify that...
This article applies to all releases of Dassault Systèmes' CATIA, ENOVIA and DELMIA V5, all...
If your SpaceMouse is moving without you touching it, it might be “drifting.” Follow these...
To check which hardware is connected to your Windows system, please follow the below procedure....
Please refer to the 3Dconnexion Limited Hardware Warranty web page for information of your 3D...
This article applies to all UNIX/Linux -based operating systems. A complete set of install instructions...
You must be in a 3D Workspace in AutoCAD to rotate your model: Expand the...
Check if your application supports the SpaceMouse. There is a list of such applications on the...
Instruction how to provide log files to Technical Support Team 3DxWare 10.8.9 or later Please...
For the Windows driver: User specific configuration files are stored in %APPDATA%\3Dconnexion\3DxWare\Cfg. The configuration files...
If your device is connected to your Windows computer, the serial number (PID) is shown...
You will find the latest available software for your 3Dconnexion device on the software downloads...
This article applies to all builds of Dassault Systèmes' CATIA, ENOVIA and DELMIA V5 on...
To speed up application launch, some users define the environment variable ADL_ODT_IN. This variable is...
Open Solid Edge. Go to "Settings-> Add-Ins ...". Verify in the list of available add-ins...
Any students at college and university level are entitled for a student discount. All we...
The Education Voucher Code expires one month after release.
You can only purchase one unit per order.
Every Education Voucher Code can be used for a single order.
Every student will get a single voucher code, which can be used for a single...
Student ID, School Certificate, Certificate of Enrollment (issued by the technical institute), Please note that...
3Dconnexion products are designed to deliver real-time interactivity when manipulating 3D content on local Mac...
