Installation stuck (macOS)
Possible reason for this issue: If your installation is stuck, it might be caused by improper uninstallation of 3Dconnexion driver, likely by dragging the 3Dconnexion folder to the trash. In the future, please use the “Uninstall 3Dconnexion Driver” file  to properly uninstall the driver.
If using 3DxWare for macOS version 10.8.5 or older you may find your installation process being stuck in this situation:
If using 3DxWare for macOS version 10.8.6 or newer, this warning message may be displayed:
SOLUTION 1A (for macOS 15.0 and newer)
To resolve the problem, please follow these steps:
  1. Go to System Settings > Login Items & Extensions.
  2. Delete the 3Dconnexion extension (click the three dots next to the extension and choose “Delete Extension”, see screenshot below)
  3. Reboot your system to complete the process.
  4. Install the latest version of 3DxWare from our website
SOLUTION 1B  (for macOS 14 or older)
  1. Force quit the installer by pressing [Command] + [Option] + [Esc] on your keyboard.
  2. Restore the 3Dconnexion folder from the Trash (right-click and select “Put Back”).
  3. Note: Do not rerun the installer at this stage.
  4. Run “Uninstall 3Dconnexion Driver” inside the 3Dconnexion folder.
  5. Reboot your system to complete the process.
  6. Install the latest version of 3DxWare from our website
If you encounter any further issues, please contact our Technical Support team
SOLUTION 2
Below you can find alternative instructions for recovering from the issue. However, please note that this requires some changes to the system. We do not take responsibility for any problems caused by these changes.
  1. Start or Reboot in Recovery Mode:
  2. Disable SIP (System Integrity Protection):
  3. Reboot. Boot into the system normally, do not go into Recovery Mode.
  4. Open Terminal:
    • Go to Applications > Utilities > Terminal
    • Run command:
      sudo systemextensionsctl list
  5. Run this command to remove the 3Dconnexion extension, using the exact extension name that appears in your terminal:
    • For macOS 26 (Tahoe):
      sudo systemextensionsctl uninstall 9D93Y2RD6L com.3dconnexion.driver
    • For older macOS versions:
      sudo systemextensionsctl uninstall 9D93Y2RD6L com.3dconnexion.dext
  6. Reboot your machine.
  7. Check status with:
    • sudo systemextensionsctl list
    • No extension from 3Dconnexion shall be listed now
  8. Install 3DxWare and follow the prompts for security and rebooting. Reboot and follow the prompt for the “Allow” button.
  9. Once completed, use the Guide in Step 2 to Re-enable SIP:
    • Check status in Terminal with following command: csrutil status (Should say “enabled”).
  1.
  1.
