How to configure remote USB in HP-RGS
This information is from HP from RGS version 5.4.8:
Remote USB for the RGS Receiver can be configured in one of three modes:
      1. Local
        • USB devices are to be used exclusively on the local system.
        • USB devices plugged into the Receiver system will not be “exported” to the Sender.
      2. Remote
        • USB devices are to be used exclusively on the Sender system.
        • USB devices plugged into the Receiver system will not be available for use on the receiver. This is the case even when the Receiver is not connected to a Sender.
        • (This mode is recommended for Thin Clients.)
      3. Locale/Remote
        • USB devices plugged into the Receiver system while the Receiver is not connected to a Sender will be used on the Receiver system.
        • USB devices plugged in after the Receiver has connected to a Sender will be “exported” to the Sender.
        • Note: Local devices will not be exported for remote use unless they are unplugged and plugged in while the Receiver is connected to a Sender.
        • Exported devices will not be available for local use unless they are unplugged and plugged back in while the Receiver is not connected to a Sender.
        • (This mode is recommended for Workstations.)
