- Click „Edit“ button on the ribbon and select „Preferences„
- Select the „Input“ category and scroll to the „NDOF“ tab at the bottom of the window. Here, you can configure most settings related to the SpaceMouse.
- Windows: Blender buttons configuration
- macOS: Blender buttons configuration
How do I enable “Fly Mode”?
Blender 4.5:
- Under “NDOF Preferences”, set „Navigation mode“ option to „Fly„
Blender 4.4 and previous:
- Under “NDOF Preferences”, set „Navigation“ option to „Free„
- Deselect all axes in the „Invert Axis Pan“ and „Orbit“ fields, to ensure the reversal of axes is disabled for a true Fly Mode experience
Blender 4.5:
- Under “NDOF Preferences”, set „Navigation mode“ option to „Object„
- Under “NDOF Preferences”, set „Navigation“ option to „Orbit„
- Select all axes in the „Invert Axis Pan“ and „Orbit“ fields, to ensure the reversal of axes is enabled
- Go to “Navigation” -> “Zoom” tab
- Enable the „Zoom to Mouse Position“ setting
- Now you can use the CadMouse thumb buttons to QuickZoom
