NX: Application Commands and View Keys do not Work After Updating to the Latest Driver
With the latest drivers, 3DxNX is installed in the 3DxWare installation directory, and references are made in the system and NX environment variables, whereas older 3Dconnexion drivers copied the components to the NX installation directory.
A conflict will occur if an old version of the 3DxNX plugin remains in the NX installation directory, even if the proper links to the latest components are made properly.
In order to verify the old driver was removed properly delete the following from the «NX_installation_path»\UGALLIANCE\vendor\startup folder:
3DxNX.dll
3DxNX.men
3DxNXPopup.men
Data di pubblicazione:
Chiedi alla community
