How to use a SpaceMouse for motion capture in 3ds Max
The following procedure describes how 3ds Max (application and plug-in) should be set-up to generate key frames using a SpaceMouse:
  1. Set the „Auto Key“ option in 3ds Max;
  2. Open the settings menu in the 3Dconnection Home App
  3. Click on “Advanced Settings” for the SpaceMouse.
  4. In “Advanced Settings”, select “Other Options”.
  5. In “Other Options”, enable “Move Object” and “Autokey Animation.”
  6. Drag the Time Slider in 3DsMax to desired key frame and move selected object with SpaceMouse
This will drop keys at the appropriate key frame when moved.
