How to enable SpaceMouse in ParaView?
SpaceMouse is not enabled by default in ParaView. However, you can easily enable it by following these steps:
1. In ParaView, go to Tools menu and select Manage Plugins…
2. In the Plugin Manager window, scroll down the list and select SpaceMouseInteractor
3. Check the Auto Load box
4. Press the Load Selected button at the bottom of the window
5. SpaceMouse should now be able to navigate in ParaView
