Advanced Settings – Other Options
For some applications you will find a tab with Other Options within the Advanced Settings of your driver. These Other Options are application-specific, and the tab will therefore only appear if you are in the application when you change the Advanced Settings (the driver must recognize the application as the active application and show you the name of the application in the top left of the window).
To learn more about the Other Options for a specific application, please follow the links below:
