- Click « Edit » button on the ribbon and select « Preferences«
- Select the « Input » category and scroll to the « NDOF » tab at the bottom of the window. Here, you can configure most settings related to the SpaceMouse.
- Windows: Blender buttons configuration
- macOS: Blender buttons configuration
How do I enable “Fly Mode”?
Blender 4.5:
- Under “NDOF Preferences”, set « Navigation mode » option to « Fly«
Blender 4.4 and previous:
- Under “NDOF Preferences”, set « Navigation » option to « Free«
- Deselect all axes in the « Invert Axis Pan » and « Orbit » fields, to ensure the reversal of axes is disabled for a true Fly Mode experience
Blender 4.5:
- Under “NDOF Preferences”, set « Navigation mode » option to « Object«
- Under “NDOF Preferences”, set « Navigation » option to « Orbit«
- Select all axes in the « Invert Axis Pan » and « Orbit » fields, to ensure the reversal of axes is enabled
- Go to “Navigation” -> “Zoom” tab
- Enable the « Zoom to Mouse Position » setting
- Now you can use the CadMouse thumb buttons to QuickZoom
