How do I connect my CadMouse Wireless/CadMouse Pro Wireless (Left) using BLUETOOTH?
Please follow the steps below in order to connect your CadMouse Wireless or CadMouse Pro Wireless (Left) using Bluetooth:
A) Make your CadMouse Wireless discoverable by Bluetooth
Push the Bluetooth “Pairing” button on the bottom of your CadMouse Wireless.
B) Start Bluetooth Pairing on your Bluetooth Smart Ready Computer
Note: Depending of your exact version of Windows, the procedure below may be slightly different.
Windows 8.1
1. Select the Start Button -> type Bluetooth -> select Bluetooth settings
2. Turn on Bluetooth -> select CadMouse Wireless -> Pair
3. Follow any other instructions that might appear.
Windows 10
1. Select Start Button -> select Settings -> Devices -> Bluetooth
2. Turn on Bluetooth -> select Add Bluetooth or other device -> select CadMouse Wireless
Troubleshooting
Make sure your device supports Bluetooth Smart as described in this article.
In case the pairing process continues to fail, please contact 3Dconnexion’s Technical Support service.
