Global Settings: overview and how to activate
  1. What is the Global Settings feature?
    Global Settings is a new feature available to the Keyboard Pro, Numpad Pro and the
    CadMouse product line. It allows you to use the same key mapping across any application. You can switch to Application Specific Settings if needed, where the key mapping adapts to the active application.
  2. Switching between Global Settings and Application Specific settings
    1. Open the 3Dconnexion settings
    2. Select the Keyboard Pro, Numpad Pro or a CadMouse device
    3. Navigate to the Buttons menu
    4. Use the toggle switch to change between the two settings:
      • When Application Specific settings are active, the toggle switch will be highlighted in blue
      • When Global Settings are active, the toggle switch will be grey, and you will see the Global Settings indication next to the name of the active application
