  1. Click „Edit“ button on the ribbon and select „Preferences
  2. Select the „Input“ category and scroll to the „NDOF“ tab at the bottom of the window. Here, you can configure most settings related to the SpaceMouse.
How do I enable Fly Mode?
Blender 4.5:
  1. Under “NDOF Preferences”, set „Navigation mode“ option to „Fly
Blender 4.4 and previous:
  1. Under “NDOF Preferences”, set „Navigation“ option to „Free
  2. Deselect all axes in the „Invert Axis Pan“ and „Orbit“ fields, to ensure the reversal of axes is disabled for a true Fly Mode experience
Blender 4.5:
  1. Under “NDOF Preferences”, set „Navigation mode“ option to „Object
  1. Under “NDOF Preferences”, set „Navigation“ option to „Orbit
  2. Select all axes in the „Invert Axis Pan“ and „Orbit“ fields, to ensure the reversal of axes is enabled
  1. Go to “Navigation” -> “Zoom” tab
  2. Enable the „Zoom to Mouse Position“ setting
  3. Now you can use the CadMouse thumb buttons to QuickZoom
Navštivte fórum - Zeptejte se komunity
Přejít na stránku technické podpory - Potřebujete dodateční pomoc?
