  1. Click “Edit” button on the ribbon and select “Preferences
  2. Select the “Input” category and scroll to the “NDOF” tab at the bottom of the window. Here, you can configure most settings related to the SpaceMouse.
How do I enable Fly Mode?
  1. Under “NDOF Preferences”, set “Navigation” option to “Free
  2. Deselect all axes in the “Invert Axis Pan” and “Orbit” fields, to ensure the reversal of axes is disabled for a true Fly Mode experience
  1. Under “NDOF Preferences”, set “Navigation” option to “Orbit
  2. Select all axes in the “Invert Axis Pan” and “Orbit” fields, to ensure the reversal of axes is enabled
  1. Go to “Navigation” -> “Zoom” tab
  2. Enable the “Zoom to Mouse Position” setting
  3. Now you can use the CadMouse thumb buttons to QuickZoom
For more information about SpaceMouse related settings, please refer to Blender Docs: Blender 4.4 Manual
