kr 1.568,00
ADVANCED 3D NAVIGATION ANYWHERE
The modern engineering workspace has become more diverse, flexible and mobile. Whether you are reviewing 3D drawings with colleagues or presenting design ideas in a meeting room, the SpaceMouse Wireless offers you the functionality to navigate efficiently in 3D applications anywhere.
kr 1.568,00 kr 1.793,00 excl. VAT
kr 1.960,00 kr 2.241,25 incl. VAT
Explore Buy Now
1 Month
Reliable Connectivity
We combined 3Dconnexion’s 6-degrees-of-freedom sensor with 3Dconnexion 2.4 GHz wireless technology and a rechargeable battery to deliver the reliability of a wired device.
SpaceMouse Wireless offers two connectivity options: work wireless via our Universal Receiver or with USB cable while charging the device. Thanks to its high capacity Li-Ion battery, you can work mobile for up to one month without charging.
*Battery life of up to one month based on 8 hours use per day, 5 days per week.
Easy to use
Each of the two buttons of the SpaceMouse Wireless opens its own 3Dconnexion radial menu. They provide direct access to up to 8 of your favourite application commands.*
With our software 3DxWare 10 you easily create your own radial menus in seconds or choose from useful presettings.
*Only with 3DxWare 10. Driver update may be required. 8 section radial menu not available on macOS.
Carry Case Included
With a mobile workplace you often change location and need protection for your mobile device. So we included a compact and lightweight carry case with a durable surface for your SpaceMouse Wireless.
2 programmable buttons
3Dconnexion 2,4GHz wireless technology
USB Cable
Battery life: 1 month*
USB Cable 1,5 m
Carry Case
Length: 78 mm / 3,1”
Width: 78 mm / 3,1”
Height: 53 mm / 2,1”
Made for each other
When you pair your SpaceMouse Wireless with a CadMouse you get a synergy we call Two Handed Power. While the CadMouse in your right hand selects and creates with ease, the 3D mouse in your left hand smoothly positions your object or view. This two handed workflow is ergonomic and efficient and the CadMouse also has helpful features to simplify your work in CAD applications.
Download Driver
