- 3DxWare:
4. Go to “Buttons”
- Inside Blender:
1. Right-click on the command you want to assign, and select “Assign Shortcut”
- The mapping is workspace-specific: this allows the same 3Dconnexion button to perform different actions depending on the active workspace (e.g. “Move” in Modeling and “Clay” in Sculpting).
- There is only one command – “NDOF Button”. It can be assigned to as many buttons as you wish, but they can all execute different functions in Blender (when “Assigning Shortcut” in Blender, the program is aware which physical button was pressed).
- The latest version of 3DxWare is required: 3DxWare 10 Driver
